113 cubic" and TMAX 112 issues
113 cubic" and TMAX 812 issues
Recently installed 113 in my 2010 fat bob. Loaded up the 812 kit which is close to what I need. I did a search and found some of same issues. here is what I have.
After program is loaded and initial starts usually {2-3} to get stable rpm, engine idled at 2500rpm up to 2800 rpm. After 7-9 restarts it idled at 1000-896 but would not run stable and would shut down. I managed t do the IAC and engine ran about 5min and shut down.
From what I have found on a thread is timing may be low on idle to 1800-2000rpm.
I have reloaded this program 2 times and will contact Zippers tommorrow.
Looking at the 811 kit maybe and change the 4.22 injector setting to 4.89.
I have had TMAX for 4 years and uploaded 96Ci stage 1, 110 stage 1, 110 2-1 propipe with cam change with no issues.
I will read the forums but anyone have ideas on this.
I have 113 kit 10.5:1 compression, SS585 cams, 4.89 injectors. Throttle body 50mm.
Thanks
Thanks
Riddarn
22
02-18-2018 09:19 PM
grows
05-31-2008 10:36 AM
