99softail won't crank!
Old 05-17-2015, 08:26 AM
wgb3470's Avatar
wgb3470
wgb3470 is offline
6th Gear
Look for the fuses just forward of the rear fender, under the seat.
Just circuit breakers and ignition control!
Old 05-17-2015, 08:30 AM
wgb3470's Avatar
wgb3470
wgb3470 is offline
6th Gear
Originally Posted by RIPSAW
Start at the battery voltage. Not just lights that you see. You can see light when there is not enough voltage to pull in starter.
After a good 24+ hour maintenance low amperage charge, with the charge light in the solid green and the battery has set about 24 hours off charge, voltage should be about 12.8 volts.
12.8 = full charged
12.6 = 75% charged
12.3 = 50% charged (Lot of new modern cars with system protection will not even click at this point but will have good headlight beams showing)
12.0 =25% charged
Always check both the terminals at the battery lead and also at the terminal on the wire. That helps to verify connection.
With a DC volt meter (one that has a feature to lock high and low reading is best) hooked across the battery terminals and reading 12.8 or so, crank motor and while its cranking it should not drop below about 9.6 volts and as soon as it starts and throttled up to 2000 rpm, voltage should read around 14.8 volts. The 2000 rpm is the bench mark standard. Ignore idle output. Ignore output above 2000rpm unless it exceeds 14.9 volts. That is a sure indication that regulator is bad. The crank check shows a rough check of the reserve amperage capacity of the battery while cranking with a 150-200 amp load on it. The 14.8 shows a good alternator and if you leave it on a while as the regulatory will drop the voltage a little showing itself working. However, with the lights and stuff always on, it will never drop back much. If you have a lot of options, most modern bikes will not show 14.8 charging volts at idle but stock newer bikes will be close. Older bikes with lower amperage output not so much. However, 2000 rpm is the bench mark for the standard 14.8 volts.
If you think battery is good and something is draining it sitting, now would be a good time to check for drain problems. Go to harbour Freight and get you a AC/DC meter for under $25 or so. http://www.harborfreight.com/ac-dc-d...ter-37772.html Make sure it has DC amps draw,DC voltage, resistance and AC voltage. Key off. Remove the negative cable off the battery. Set meter on DC amps. Hook the meter lead to cable and the other to battery. How many milliamps (mA) is it drawing? It should be no more then 6 mA which is the ECM (1), speedometer (1), tac,TSSM (1),HFSM (1) and voltage regulator (1)
When a battery wears out, a good charge will show fairly good voltage, but the battery can still have very low amperage capacity which will show in the crude crank test above, but it really should be checked after a good charge by removing it from bike and getting a free check at a place like AutoZone that has a fancy load meter check that gives you a print out of the battery health. Battery MUST BE CHARGED to check it. Be sure they set their meter to correct cold cranking amperage stated on the battery. Never charge the AGM absorbed glass mat battery with a regular car battery charger unless it is a newer one that says safe with this type of battery. Also, by taking battery out you now know you have good connections. Vibration tends to loosen the connections or a little corrosion will prevent charging or cause starting problems. Using the maintenance charger can get more years from a battery but be careful here. You do not want the last start 5 miles from home. If it still grunts when you first hit starter or kicks back with a bang, replace it. After a few years, charge and pull battery and have it checked for cold cranking amperage ever spring. Even then, if it grunts most ever start, I would replace it. If they have one that fits your bike, Wal-Mart's AGM absorbed glass mat battery is just as good as any for one third to half the money of a Harley Battery. Do not jump, push start or run bike with a half dead battery except in an emergency. If a bike battery is down and you jump it, throwing all that amps to it from a big car battery especially one that is running can wreck a bike regulator or charging system. Charging a worn out battery can kill alternator stator or the voltage regulator or both. Probably a big dollar repair. It is also a good idea to always check your battery at 2000 RPM with your meter set to AC. If by chance, the regulator goes bad, sometimes it will let AC come thru. That is a sure sign of a bad regulator. The older stators with two wires is a two phase AC system. Lot of people call it a single phase but it is two phase. The AC voltage you see appears single since you check it AC across the two wires since there is no earth ground. If you were to check one wire to an earth ground, it would show one half the voltage that you would see when you check the two wires together on the bike. Same with the other. Together they double and are two phase. The newer 3 wire system is a 3 phase AC system for the higher amperage output.
Also remember, when starting a Harley, hit the starter and hold it in till it is firing on both cylinders and running before letting up. There is a fraction of a second more for a long stroke Harley then a multi-cylinder car for it to get going. If you do not do this, it will kick back with a bang or crank a lot longer the second time or shame on you the third time. Also, if you have a habit of doing this, the starter solenoid switch contact will only have half the life it could. You cannot hurt the starter. The starter gear has a sprag clutch. There are drive pins in it that as the gas motor catches and run, it outruns the starter motor drive and disengages it from the electric motor.
Thanks for the info ripsaw. But it deffinitly not the battery or starter. I've checked all that! Something keeping the bike from firing up. The starter turns over great when i jump the relay! But won't allow juice to the coil.
Old 05-17-2015, 09:17 AM
hawwk's Avatar
hawwk
hawwk is offline
Did you do anything recently to the bike? Like changed handlebars or switch covers? I would try and bypass the kill switch and see if it works
Old 05-17-2015, 09:19 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,497 Likes on 4,612 Posts
The schematic I have shows fuses for a `99, but it is obviously not accurate to your bike, however, the breaker for the ignition is wired into the system just like the fuses.
The copper stud on the breaker is on the battery side of the circuit, and that stud powers terminal 30 on the relay, and will continue to power that leg of the circuit even if the breaker trips.
The output side of the breaker (silver stud) sends power to the kill switch, and also terminal 86 of the start relay.
If the breaker is tripped/dead, or the wire is bad/shorted to ground somewhere after the breaker, that leg of the circuit will be inop.
If this is the case, you could jump terminal 30 to terminal 87, and the starter motor will crank, but since there is no power on the other leg of the circuit (after the breaker), the ignition system will not get power, so all the engine will do is crank over.
Check that ignition circuit breaker and see what the voltage is at both terminals while the switch is turned on.
Old 05-17-2015, 10:42 AM
wgb3470's Avatar
wgb3470
wgb3470 is offline
6th Gear
Ok bud thanks! I just had the tank and fenders painted. Rode the bike about 100 miles the day i finished puting it together. This happened the next day.
Old 05-17-2015, 10:43 AM
wgb3470's Avatar
wgb3470
wgb3470 is offline
6th Gear
Ok!! Try that next! Bbs!
Old 05-17-2015, 03:45 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,540 Likes on 3,792 Posts
Jumping it overrides the on/off safety switch on the bars. May have already been said. If someone switches mine, I probably would be pondering for a few
Old 05-18-2015, 02:49 AM
wgb3470's Avatar
wgb3470
wgb3470 is offline
6th Gear
Loosened the tank up and found the problem!! Wires from the bars have been pinched for awhile. Finally grounded out!!! Thanks for all the input guys!!!! 150 miles yesterday and no probs!!! Yee haa!!
Old 05-18-2015, 04:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks for the update, glad you got it sorted out.
Old 05-18-2015, 06:38 AM
hawwk's Avatar
hawwk
hawwk is offline
Glad you found the problem
Quick Reply: 99softail won't crank!
