Very first issue on my 06 softail classic 34k
I have an 06 heritage softail classic fuel injected w 30 k miles last Sunday took her out on hwy opened her up, for little while, climes up to about 115 mph hwy was clear, nice day, parked at my favorite watering hole, in ft lauderdale,6 hrs passed and time to go home,cranked up fine, but then it started to sputter backfire and no power, felt like it was running on 1 cyL barely made it home, next day I put new champion plugs still same backfire let of throttle it would shut off.did a diagnostic test and I get 2 part numbers pn141npoo2-0. The other pn67033-04a the it said no rsp
Also pn68923-00d. P says none 5 says none 5 and p together say none last letter says no rsp.i would appreciate all the inside and opinions in English pls, I'm 60 percent mechanic bad tuner, power commander 3 usb Vance Hines air cleaner upgrade. I have no choice than to fix my self, unemployed time beighn. Thnx to all who reply.
Let us know what you find. My friends 06' Dyna is doing something similar.
https://www.hdforums.com/forum/engin...-cuts-out.html
The NONE means no codes in the module you are looking at.
"P"= Powertrain (EFI)
"S" = Security (TSSM)
"SP" = Speedometer.
I'm assuming the last letter was a "t" and you don't have one hence the "no resp"
Unplug the power commander and plug the bikes harness back into the ECM and see if it starts firing. A coil driver in the power commander may be out.
Replace battery and clean and tighten battery cable ends on all 4 ends. Go from there. Are you running an aftermarket tuner or flash tune? Is your "parade mode" activated or deactivated? I would also do a push/pull wiggle test on your main harness that plugs into your ECM. Also check all connections while under your seat.
