PV AutoTune Pro Problem
Old 05-30-2015, 10:44 AM
JamieDTR's Avatar
JamieDTR
JamieDTR is offline
Default PV AutoTune Pro Problem
I have the power vision I have been running since last year. Never had an issue with it. I just purchased the AutoTune Kit, and installed the Wideband O2 in my new pipes. When I try to run AT Pro, no grids fill in and the main screen shows no changes made. If I disable, then run AT Basic, everything works as it should. In Pro I get WBF:! WBR:! Errors. All my wires and plugs look fine. Could my brand new O2's be faulty?
Any help would be appreciated!
Old 05-31-2015, 08:29 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Either the wide band sensors, or their connections are faulty.
It's highly unlikely that both sensors would be bad out of the box, so I'd go over the wiring again. Check from the sensors to the adapter box and then from the adapter to the PV. Something isn't right.
Old 06-01-2015, 03:12 PM
baloot-boy's Avatar
baloot-boy
baloot-boy is offline
I just installed mines last week with no issues. You can try this test as shown in the Autotune instruction manual:
http://www.powercommander.com/downlo.../at110_120.pdf
O2 sensor test
1. The Auto Tune kit has a built in circuit which allows
you to test the sensor accuracy and condition.
2. Remove the sensor from the exhaust system and hold
in ambient air.
3. Verify the Auto Tune kit has been powered up for at
least 1 minute.
4. Press and hold the function button on the front of
the corresponding Auto Tune kit for 3 seconds and
release the button.
5. The LED light will blink rapidly, pause for a moment,
and then begin to flash.
6. Count the number of flashes and refer to the chart.
7. Retest the sensor if there is any question as to the
purity of the air during the test.
Old 06-01-2015, 04:23 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,103 Likes on 1,339 Posts
Most likely either the CAN termination plug is not plugged in or is loose at the AT module or the data cable does not have a proper connection either at the PV or the AT module. The LED on the AT module will blink as the sensor are heated, after about 30 seconds it was stay lit meaning the sensors are live and operational.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
JeffJA (05-30-2018)
user 46092
08-16-2013 09:21 AM
deadwood1584
07-13-2013 06:28 PM
Siddyboy
12-03-2012 11:52 AM
trapper_canada
06-01-2011 11:26 PM
cdn.biker
06-13-2006 03:43 PM
Quick Reply: PV AutoTune Pro Problem
