Fuelpak FP3 cam change question
Hi All, rather than hijack someone else perfectly good discussion...
The FP3 now allows you to change the IVO and IVC to cater for new cams, which gets us past the stage 1 tuner label it used to have. I've also read a couple of threads where you send your map to V&H and give them the cam specs and they send you a new map back.
Thing is, I put in an Andrews 57h which is not exactly anywhere close to the original 2014 softail yet was advised that nothing needed to be changed and just do an autotune.
I started with the 2014 Softail 103, Pro Pipe, and hi-flow AC - runs ok ish but way too rich. Auto tune made it worse and really messed up low throttle around the town.
Does anyone else have a 57h that their IVO and IVC were changed that I might try your values? (actually the numbers in there don't seem to correspond to an actual angle you can take off the cam spec so it's not as if you can do it yourself)
cheers for any thoughts G
By the way - does anyone get any MPG readings to show?
Unless the cam specs are nearly identical to the first cam, you'll most likely need to reset the VE's to start with. Failure to do so will probably result in wrong numbers in most cells.
...sorry, forgot to mention that when I said it was way too rich - I meant it stinks to high heaven especially at startup but also sat at lights even when warmed up, and I can't get rid of the P0132/52 front/rear sensor rich codes ...unless I put the map back to stock.
Some of the autotune that I was trying to do was pulling the VE down in the cruise range to 58 so at least its trying to take the fuel out.
I did read about a couple of success storied about FP3 and 57h ...I was hoping for more than 77HP mind you
I have made the changes and sent it back directly to your phone. You can download and flash anytime.
Cheers Chris, really appreciate that and will try to get out at the weekend and let you know.
I see what you mean about not having to change cam timing by the way, car tuners don't change anything either, unless the cams are rather radical... I'm learning (ok ok, slowly)
Now that you mention air leak I've just remembered that when I installed the pro pipe I noticed the end of the header pipe was "rounded" rather than having a bit of a tapered like the original stock headers. I used new tapered seals (as the instructions advised) and while I don't think I can see a leak ...quick sanity check - should the seals be the new tapered ones or old flat ones
Good luck Gordon,
I also have the 57h with map adjusted by Chris. while I use a different pipe than you it would be interesting to compare tables once you're done. I have not autotuned my most recent version but might once I finally decide which end cap and number of disks in my supermeg to use. The map that Chris worked on for me is based off the propipe though.
On the potential leak, have you done a test yet? Lots of ways to do it but I simply used a long lighter and floated it around the exhaust header ports to see if the flame would be snuffed out.
Enjoy
Enjoy
A quick shot around the block tonight and there is still a bit of a petrol smell but not as obvious and no error codes so far.
I'm pretty sure there's no leak but I'll get the torque wrench out again and just double make sure they are tight enough just in case they have given a wee bit more than expected after a few hundred miles, and then triple check there are no leaks again
@Robby, will do, let me get an auto tune in the bag over the weekend. Hopefully this one will come up better.
I just couldn't make my mind up between the Pro Pipe or Supermeg, the reports put the two pretty level performance wise. The Supermeg was just too expensive here in the UK so I went Pro Pipe and am more than happy. I also preferred the mounting bracket on the frame instead of the transmission case, but that probably doesn't matter.
