2010 FLHX throttle body issue
I was out riding today and no problems. Pulled up in the yard and slightly raced the engine and exhaust popped. Weird? Then the bike was idling at 2000 rpm. Then I noticed a loud noise behind the air cleaner. Great stepper motor has failed maybe. I have code p1511 p2101. I noticed my V&H tuner numbers not moving. Did this cause the problem, not sure. I removed tuner and same problem. I can clear the codes, runs fine but buzz's constantly them back into limp mode and codes. The stepper motor buzz's loud when you key on or running. If you touch the throttle blade it vibrating.
Anyone seen throttle body make this noise? I believe its bad. I don't think its the bad connector issue.
Z_Stingray
05-27-2008 07:34 PM
