How to check IAC
I'm not seeing any movement when I turn on the ignition. When cold it starts hard and idles, runs rough until it warms up. Once up to temp it runs pretty well. When up to highway speed I still notice an issue when letting off, feathering the throttle in 6th gear. Runs good when accelerating (calling for fuel) up to speed. I have an additional tmax and the stock ecu. I have tried all three and I still can't see the iac move when turning the ignition on. Spayed with carb cleaner and still nothing. I'm thinking that the iac has failed. Do they fail often? Hard to change? Bike has 38,000 miles on it.
Actually it will move (I believe out) when you turn it off. Then after a short warm up period it will move the other way. If it is not moving it is toast. Straight forward process, but you need to get a voltage reading off of the TPS prior to removing the IAC so that you can set it to the proper position after the new IAC is installed. .
When you turn the key off it goes totally closed and then retracts to it's parked position. That's determined by a "constant" setting and then it has "warmup steps" and "crank to run" steps added. Not all tuning devices give access to these tables, some only to the warmup enrichment tables. All of the tables except the constant setting are temp based and decay over time. A cold parked position may be 120 "steps". The ecm will take control of the steps based on the throttle plate postion to control idle. Usually I will adjust the throttle blade to show 40+/- steps at 105*C. This allows it enough room to move in both directions.
anything2wheels
Carburetor Related
15
06-26-2019 10:59 AM
