Evo MM hard starting
Bike is cranking a lot more then usual , when started it runs fine , fuel pump pressures up in about 3 seconds and engine light goes out - all as usual and has no codes ( when i do the key on/off thing the engine light flashes very fast but according to the book this means no codes ) watching the stepper motor on the manifold it works in and out like it should
Any ideas where to start , when cranking if i give it throttle it will pop and then start after that it starts fine as many times as i try it , just the first cold start seems to be the issue
Thanks
Dave
Thanks
Dave
