Need help with Fp3/ Stage one issue
Good Morning All,
I installed V&H Dresser Dual Headers, V&H Twin Slash Round mufflers, Arlen Ness Big Sucker, and Fuelpak yesterday. I flashed the bike with the associted CAN map provided by V&H. I have an issue now. The bike seems to be running sporadically. There are hard vibrations from 3k rpms and up, and I mean ROUGH. The throttle response is sluggish and inconsistent. If I crack the throttle the bike will lurch forward then settle down, then lurch forward again. I checked the diagnostics on the fuelpak and it said I was running to rich then to lean. It recommended running the auto tune feature which I am doing now. I have re tightened all the bolts and there appears to be no leaks at the cylinder heads. Also when the rpms drop around 2k the engine sounds as if im at 500rpms, the lugging and chugging is horrific.
I will be contacting V&H tonight to see if they have any suggestions, whether it was an installation error on my part or maybe I need to continue to auto tune. Any ideas on what the issue is. This is my new 2015 street glide special I just picked up after trading in my Street Bob which I had also brought to stage one without any issues. Any information would be greatly appreciated thanks all.
Matt
Matt
You almost hope there is something wrong like getting the sensors mixed up, although you can't do that on softail because of wire lengths and such but I don't know the street glide
Hope you find something silly to laugh about after
Good Morning All,
Matt
Matt
@mndelrosario- You sent an email this morning as well, and the screen capture you sent had P0151, P0152, P0131, P0132. Which is rich and lean codes. This means that your O2 sensors are transposed. This will throw off the Adaptive Fuel Values and dramatically effect the overall run-ability of the bike. Swap the O2 sensors to correct front-in-front, rear-in-rear and then flash the same map again. This will clear the Adaptive Fuel Values (it started learning incorrect values as soon as you started it) and start fresh.
