Power Vision Dyno Tuners
I have recently installed a FM stage 1 AC, RCX Power Max header and a set of RCX 4.5" slip-ons on my 2014 Ultra Classic. I have flashed the ECM with my Power Vision and a map from FM. The bike seems to run ok but rich at idle. I am considering having it dyno tuned or installing the Dynojet Target Tuner as I am challenged in the tuning area. Any suggestions on tuners located in the Central Ohio area or the Target Tuner? Or would I be better served working with Fuel Moto to get it right.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
For fine tuning your Fuel Moto map I would recommend using the Auto Tune Basic application with your Power Vision. This works very well and allows you to automatically populate tune corrections using the factory O2 sensors.
We generally recommend three, 20 minute sessions- updating the tune between each session. If this does not correct the issues with your tune you are welcome to send us the tune you created with Auto Tune and we will take a look and make any necessary adjustments. If you need any assistance you are welcome to contact us with any required tuning support or questions along the way.
You can view the instructional video here
Here is the user guide for reference http://www.powercommander.com/downlo...utoTune.01.pdf
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
denman
05-12-2016 06:57 PM
tcrideshd
21
05-28-2013 09:56 PM
