Welch plugs
Measure the size and thickness you need, then go from there. Which plug did you drill?
https://www.seastrom-mfg.com/expansion_plugs.aspx
http://www.imperialsupplies.com/sear...ring=expansion
Also depending upon the size, you can cut some aluminum rod to make your own. Slice the rod like a carrot and peen it slightly. Use a little (just a little) Loctite on the plug when installing. Could also stop by a local small engine repair shop. They may have something. YD
