TP Code - Might I have found the real problem.
Old 10-20-2015, 03:30 PM
SoonerSoftail's Avatar
SoonerSoftail
SoonerSoftail is offline
Default TP Code - Might I have found the real problem.
Back in May the bike sputtered a couple of times and died. Started up and went a few miles then did it again. Started right up and got home. No codes in the ECM. It's run OK since but it has had a lean-like cough at (according to the Power Vision) 5 to 30% throttle and 1500 to 3500 RPM.
Since this felt like a fuel problem I had the injectors cleaned and bench tested, replaced all the in-tank fuel lines, pump, regulator and filter. Changed the intake manifold seals. Also changed the plugs, wires and exhaust gaskets for fun.
That did increase the fuel pressure and she ran much better.
Then today it did the same thing it did back in May. Sputtered and died. Sputtered and died. Now it will idle but as soon as you give it any throttle it dies.
This time however the PV shows a "P0122 TP Sensor Open/Low EFI" code. Could a TP sensor cause the sputter and die problem?
Old 10-20-2015, 06:52 PM
J929626's Avatar
J929626
J929626 is offline
Yes it can. If the ECM does not know the position of the throttle plate then it can't run correctly.
You can also get that code with damaged wires or dirty contacts.
Old 09-13-2016, 08:11 PM
Montamayor's Avatar
Montamayor
Montamayor is offline
I suggest start cleaning/spraying the TPS through the vent it has. Big chance this will correct your bug.
Old 09-14-2016, 07:53 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
You cannot clean the Throttle Position Sensor by spraying anything into the throttle body. If you mean cleaning the throttle body, that is most likely not the cause of this concern.
Check for a broken wire at the TP sensor where it goes into the rubber insulator of the connector.
You really need to have a scan tool and watch the TP sweep, but a broken wire could certainly result in the condition noted above.
Renoir1
09-07-2016 08:48 PM
saz
Engine Mechanical Topics
05-17-2016 10:22 AM
AGWalker
06-15-2014 12:12 PM
PappyUSMC
05-07-2013 10:21 PM
Kowalski
05-04-2010 02:08 PM
Quick Reply: TP Code - Might I have found the real problem.
