THUNDERMAX: ThunderMax PN#309-562 for stage V
Hello,
Does anyone have any experience with the ThunderMax PN#309-562 used on touring 2014 and up ?
I currently have the FP3 and I plan to leave the 12mm on and switch the ECM with the ThunderMax PN#309-562 to see witch one I want to end up with.
My configuration is with the bolt-on 110 stage V 92500037
110 cylinders
CNC ported heads
10.75:1 compression (using .030 gasket)
SE-259E cams
58mm throttle
5.3 g/s injectors
SE clutch spring
SE tappets & perfect push rods
Thank you all for sharing your experience
110 cylinders
CNC ported heads
SE-259E cams
58mm throttle
5.3 g/s injectors
SE clutch spring
Hello,
110 cylinders
CNC ported heads
SE-259E cams
58mm throttle
5.3 g/s injectors
SE clutch spring
110 cylinders
CNC ported heads
SE-259E cams
58mm throttle
5.3 g/s injectors
SE clutch spring
There are two 106ci throttle by cable maps (itemid 871 and 872) that are close to your build. Copy and paste the timing tables from one of these 106 maps into the 110ci throttle by wire map (itemid 319). that will get you close.
With the thundermax, you do not have to worry about the AFRs. Autotune will take care of it. You do have to worry about timing. A map that has the same stroke and has similar bore, compression, and intake valve closing will have timing that gets you close to the mark.
Check Thundermax website, 309-562 comes with 18mm 5 wire o2 sensors that have to be installed close to head like a 2009. 12mm are 4 wire 02 sensors. Have been researching this ecm for my 2016 FLHXS. I am new to all this electronic stuff as I have been riding a 92 evo for the last 23 years, please don't take this as gospel. Brad
to copy a table click on any point in the table then press shift/Ctrl/C. That will copy all timing or AFR points for that table. Close the map, open the target map and paste the copied table. To paste, click on any point in the table then press shift/Ctrl/V. Save changes the repeat for every table you want to copy
The 310 is a close match. The 871-872 maps are nearly identical to the 310 with the exception of the slightly larger bore. Could be a good start. The timing is still different. Give the 310 a go and see how it does. You can still do as mentioned and copy the timing events from 871-872 later into the 310 if needed.
1 Post
Done
2014 Ultra Limited (Twin Cooled), Rinhart Slimduals, ThunderMax (2014) and 2016 Stage V 110 Bolton,
92500037 - Stage V kit $2,300
29400223 - 58mm Screamin Eagle Cleaner $360
309-562 - Thundermax ECU $720
Redline - WaterWetter $22 ( replaced the antifreeze coolant - please note this is being used only on climate with temperatures above 32 degrees.
Labor 10 hours @65/hour $650
Parts bought from Boardtrackerharleyonline.com
*** Note - This kit is for the Air Cooled but I asked the vendor to switch the CNC ported heads with the CNC ported water cooled.
I received the kit about 45 days after I order it. The parts were very well packed and the quality was surprisingly good, perhaps because the parts are all race Screamin Eagles.
Installation was straight forward, it could have taken less time but I was a bit picky with the mechanic. The head gasket I used was the cometic .030 that changed the compression from 10.5:1 to 10.75:1. The only thing the mechanic had to adjust was 2 piston rings gap by filing the ends to spec. I had installed the 18mm O2 sensors but left the narrow band on as well.
After the bike was ready to start I used the HD super tuner and flashed the ECU with the stage 4 calibration. There is a Stage V calibration but it did not allow me to flash it with that calibration since that is for the air cooled.
I started the bike and it sounded horrible. I stopped the bike and used the FP3 to flash the ECU, I made the cam changes, displacement, fuel injectors etc, and put it in Autotune mode. Started the bike and it was much better. Left the mechanic and stopped about 20 miles into the ride and flashed the 1st autotune data and that made the bike run about 100% better but still far from good. The following day I installed the Thundermax ECU, I used the base map #305 - I set the Idle RPM and performed the Kick Stand Tuning. The first 200 miles the bike was running like day and night difference. I have changed the map to #310 since the cam specs are bit closer to the SE-259E I have on the bike. I followed the process again (Idle RPM and performed the Kick Stand Tuning ). I put about 200 more miles and changed the oil and filter.
** The Bike Runs Like a Swiss Watch ** - Please note that with the new Thundermax there is no need to link to the computer anymore to write the learned data. It is automatically written every time the bike is cycled off.
So in summary I'm very pleased with this kit, lots of power, it sounds way better than I expected, and the bonus....it is way cooler, perhaps with the aid of the massive air cleaner and the Red Line WaterWetter coolant.
Although it may sounds simple but I did a lot of research and preparation and asked a lot of people for help to fully understand what I need to do.
STAGE KITS – RACE 61
SCREAMIN’ EAGLE® PRO 110CI STAGE V TIRE SHREDDER KIT
Heat the rear tire for a perfect green light launch. Now you can build a track-ready 110 cubic inch big bore monster without removing the engine from the chassis. This kit features exclu- sive bolt-on 4.0" bore cylinders that are engineered with high strength steel liners that slip into the existing Twin Cam crank- case openings. Installation does not require case machining or modification.
Kit includes the following Screamin’ Eagle components:
• Big Bore 4.0" Bolt-On Cylinders
• CNC-Ported Factory Cylinder Heads • Forged 10.5:1 Compression Pistons • SST Piston Rings
• SE-259 cams
• Perfect-Fit Pushrods
• High-Capacity Roller Tappets
• 58mm Throttle Body
• High Flow Fuel Injectors
• Heavy Duty Clutch Spring
• Top End Gasket Kit
• Cam Cover Gasket
• Super Tuner EFI Tuner
Kit also includes the Screamin’ Eagle Pro EFI Super Tuner module to provide on-track tuning for maximum perfor- mance. When installed with your choice of 58mm high-flow air cleaner and free-flowing exhaust, this engine has the potential to produce 113 horsepower at the rear wheel. For race appli- cation only.
92500037 Black Highlighted.
Fits ’16-later Softail® and ’08-later Touring and Trike models with 4-3/8" stroke flywheel. Does not fit Twin-CooledTM models. Cannot be installed on CVOTM 110 models, FLSS or FLSTFBS 110 models, or models with engine cases that have been machined to accept large-bore cylinders. Requires separate purchase of accessory 58mm air cleaner and Cam Drive Retention Kit P/N 25566-06. Cam Spacer Kit
P/N 25928-06 is recommended. Models without automatic compression releases require installation of model specific Compression Release Kit and Wiring Harness.
• SE-259 cams
• Cam Cover Gasket
CarlFitzwater
01-21-2018 11:26 AM
