Fuelpack 3
I haven't done it so I can't speak from experience because I installed it along with the stage 1 kit @ the same time.
I am pretty sure that running a stock base map and using the auto tune feature will richen up the map because WE all know these bikes maps arrive extremely lean from the factory for emissions reasons etc. therefore by adding fuel it should cool your bike down and in return add a little power or at least run a little smoother
If you do enrichen the air-to-fuel ratio using the FP3 you have to be careful not to go too far as it can clog the catalytic converter. It won't happen "overnight" but it will over an extended amount of time. The amount of horsepower and torque gained will be negligible until you change into at the very least a "Stage 1" upgrade.
On a side note, you will see some gains in stock form, (2-3hp) using the FP3. 4-5hp using a high flow air filter and everything else stock. But as OldEnuf2NoBtr said, you will see the greatest change by changing out the complete exhaust and intake all at once. Typically a gain of 10-12% depending on the setup.
