Throttle body cleaning
Do not spray. Take a cotton cloth and spray it. Then clean around butter fly. The throttle by wire still have a combination sensor and throttle position sensor. Not sure what it would do but the butter fly edges and around where it hits is all you need.
The older cable models will wash crud up past IAC valve o-ring and destroy the motor making it stick. It will also hose up the idle position sensor if it runs up the shaft and gets on the resistor rub face.
The air going thru there is clean and way to slow to pull oil in. What you see is from the spit-back and the fuel injector wash that dries up. It can crud up the metered area around the butterfly since that is the biggest part of the idle or give the throttle a little stick coming off idle if it really is bad. The idle trim from cold starts and actual control is from the IAC valve or on the throttle by wire motors, the butterfly motor.
Most people do not realize the the throttle by wire body is about 1/3 cheaper the the older cable one. It also bumps the throttle rpm on throttle off which gives the engine more air to decrease pollution. This enabled Harley to add a better fuel ration for more power across the rpm range.
tkenney2nd@yahoo.com
10-26-2016 03:32 PM
elbohead
06-11-2013 10:13 PM
