Ignition Coil leaking goop!
Thanks NomadMax.. I asked him about that, but his pride might be too much to admit it. I checked his ignition switch and it looks to be ok. Any electrical tests you can recommend to see if the coil is still getting power when the key is in the "off" position that are beyond the obvious ones with a multimeter?
Yup, somebody left their ignition switch on. That's one reason why I hate kill switches to shut down the bike. You can forget about the iggy.
If the coil is leaking then there's a crack in it from the heat. Leaving the ignition on will cook the coil and can wipe out the electronic ignition also. Don't even try to use the coil. Replace it and hope for the best on the ignition.
I'm not getting spark to the rear cylinder. Coil is brand new OEM, ohmed it out and it's in spec. Old coil was not. Opened up the electrical box on the dyna and noticed that it looks like the ICM melted a little bit as well. Here's what I've got so far:
- Swapped coil wires - Still no spark in rear head
- Tested pins 6+1 and 7+1 on ICM no continuity while trying to turn over motor (manual says test light should flash) (from back of connector while plugged into the ICM)
Ok, so the plot thickens! Love it when I don't get the full story. So he trailered the bike to the house to replace the coil, wires, brakes and 3-hole fluid change. Went to go start the bike and noticed the back head wasn't firing.. WTF?!?! Called him up and he was like "yea, started running like ^%$# but then I turned it off"
Yes sir.. front head was getting spark. Weak spark.. but spark none the less. Back was getting nothing at all. What I don't get is how I didn't see any continuity between pins 6 or 7 while trying to turn the bike over. Just went out there to double check and the damn battery is dead from me messing with all the tests. Got it on the tender now.
