Codes
Codes
Last started bike a week ago. It took a little but Started up. Ran it for a half hour. I did ride a few times since Jan 1st. I have scream eagle motor with mechical compression release. Today I went out to start it and the bike just kept turning over and over and over but would not start and the mechanical releases would not pop back up. Hd out the motor in 25k miles ago. I have 48k on now. Not sure if that makes a difference. Battery and plugs were change 2 years ago or under then 10k miles. Last time my battery was dead when trying to start it. This time not so sure if battery, plugs, tried gas cover remove thing. Any help so I don't go buy a battery if not needed or.... P code read pn32915-06, a code read pn68922-00d, sp code read 67083-04a and e code read no rsp only. Ty 2006 road king classic fuel eject, with factory alarm u press fob.
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Like Tom said above pull the battery, charge it and load test it. Does the fuel pump come on for a few seconds when you turn the key on? Pull 1 plug and ground it and see if it's firing. Can you see fuel on the plug or smell it in the cyl.?
