Optimum AFR
The twisties are about 100 miles away, no problem but not sure its 45 minutes worth maybe turn around and head back.
Before I do anything I need to have a possible intake leak taken care of. I would do it myself but I have very little confidence in me doing it. In fact I was the one who installed the t/b after HPI rebuilt it. Not crazy about paying the dealership to do it but if I do it I have no idea if I can tell when I tighten the bolts if I did it correctly. Will have start it to see.
Around for extended periods of time just to gather data.
I did a two minute idle log a couple weeks back. Jamie said it looked like my front cylinder was very rich and the rear was lean which corrected when it went into closed loop. He suggested I look at the IAC or intake leak. I switched out the IAC with the one in my "07 Deuce, no change even put the SG IAC in the Deuce no change in the Deuce. That is why I need to check for an intake leak, which I did but want it confirmed by someone who know what their doing.
After I get that straightened out I will do 45 min log.
I don't know what part of Oregon you live in But I lived in Salem Oregon for 46 years and there is 100's of miles of twisty roads.
kishstl
15
04-21-2014 11:55 AM
