2000 harley ultra no spark
I was going down the road and engine just stopped. After getting it found some blown fuses. replaced fuses, the coil will not fire, I have power to coil. checking sensors and they seem ok hardness, and ECM ok, Im getting what I believe is all clear codes
Codes reading do1clr,do2clr,do3clr,do4clr,do5clr,do6clr,do7clr,d o8clr,do9clr,do10clr,CAL03. Any ideas would be greatly appreciated. when I try using check engine flashes all I get is 12 flashes.
"blow all the fuses"? If you had all the fuses blow, you've got serious electronic problems, probably due to a bad voltage regulator causing an extreme overvoltage.
Also, if you say "no code", but then list a series of codes (which I'm not going to look up, but if you've got a whole series, it's probably telling you sensors are bad, missing or out of spec.) You don't say if you are using a tuner... Going to need lots more specific info before anyone can help..
fiddledicksr
16
12-27-2005 12:20 AM
