Help! Front left signal out, back left blinks normal then fast
Just bought my harley sportster custom 2007 and realized that the front left signal is out. They're aftermarket bulb blinkers. I checked the bulb and its one filament seems to be good. There was some corrosion (white dusty stuff over rust) that I cleaned off to make sure it was making a proper connection, but that didn't help.
Wondering if anyone would have insight at what could be going wrong/what to check.
Thanks all!
-Bliss
Thanks all!
-Bliss
It sounds like you have a wire break somewhere. It should be obvious when you go to trace it because if it was hidden it probably would be touching something and therefore pop the fuse and none of them would work. Unless it's the ground. But just start at the light and work your way back. Anywhere there is electrical tape, remove it and take a look. I say all this assuming when you say aftermarket bulbs, you mean aftermarket turn signal assemblies...
If your headlamp is working then the problem is in between your main wiring harness and the turn signal. You can lift the tank, disconnect the turn signal from the main wiring harness, and check for continuity between the pins on the wire from the turn signal. If there is no continuity, remove the bulb, then check for continuity between the bulb contact points and the pins on the turn signal connector. That step just tells you which wire is bad and may not help much though. If you can't get continuity through them both, inspect the wire and you may have to take the housing apart to make sure you are making contact from the wires to the bulb terminals.
One more thing to check. Take a look at the relationship of the pins to the bayonet channels on the reflectors. I once had the spring loaded contact pad rotate out of position. No idea how it happened, but when I went in with a multimeter to test I noticed it looked "different" from the side that worked. Got a hemostat, rotated it and it popped back into place and the world was once again a happy place...
Edit: Oh boy, did I read that it's a single filament bulb? If so then disregard what I wrote. Sorry.
Andrewnc
06-27-2018 07:50 AM
