Thinking of changing my afr from 14.0 to 13.8 to run cooler, will it help?
Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Thinking of changing my afr from 14.0 to 13.8 to run cooler, will it help? If it will not make much difference then I do not want to waste my time hooking the lap top up and doing all the stuff you have to do to down load the new map in the ecm. I ride through the desert a lot, last year going through Mojave Desert it was 111. The bike ran hot but it ran. Any thoughts about this. At stop lights when the bike is at idle it gets hot and the temperature management is active any thoughts how to cool the bike at stop lights?
You know you can do all you want with the AFR tables or Timing Tables however if the VE tables are NOT synchronized correctly you don't have a clue what the AFR really is. The Fuel table is only a request table....it is NOT actual AFR if the VE tables are off.
Doc
