Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
You can only get the benefit of wide band sensors if you use a tuner designed for them. Just installing them on a stock bike won't work.
One easy, cheap way to make the bike run cooler is with a set of XIED's. But the best way is to get it tuned properly.
I have a Screaming Eagle tuner, Stage 1 and true duals.
"Changing the O2 sensors to a wider band will allow the engine to run cooler?"
If so, please be specific.
No it isn't true. Just switching over to a WB isn't going to make anything run magically cooler. It is just a sensor that puts out a voltage. It's a pretty vague, out of context statement.
