HI-4N Ignition S&S Timing
Hello have a few questions all help is appreciated
When changing settings on ignition do you have to retime until light goes off on ignition ?
When timing until light goes of on ignition I hear the coil click is this normal ?
Ignition coil Daytona Twin Tec High Output Single Fire Coil (3post)
When checking for spark with screw driver from coil to spark plug boot I will get a spark from one spark plug wire but not the other is that because they fire different?
