Take a look at these plugs
It hasn't been dyno tuned. Before I do that, I would just pop for AutoTune to go along with the PCV. The only reason I haven't done that already is that I would have to replace the headpipe as the O2 sensors for AutoTune are different sizes than the ones on my bike (and they need to be closer to the head too, I believe).
You have a running issue. You don't know if it simply a tuning issue or something in the system causing the condition.
By purchasing an "autotune" system you will not diagnose your issue, rather the autotune will attempt to correct fueling even if there is something wrong causing the issue. In other words, autotune will be nothing more than a bandaid to get around an engine management issue.
Upside to a proper dyno tune...identifying and diagnosing running issues before tuning will prevent bandaiding so the tune will go as expected.
Downside to a dyno tune...gotta get there.
JME, Bob
