Take a look at these plugs
All
Take a look at these plugs - darker one is for the rear.
2011 FLTRU with SE Ventilator AC, CVO slip-ons and de-catted head pipe. Using Power Commander V for tuning.
No power issues - no idle issues. No issues at all really other than doing normal maintenance and decided to check the plugs at 15k miles. Last replaced at 10k.
I am am happy with the front. The rear looks like it has carbon deposits on it.
Thoughts?
Thoughts?
UPDATE: Checked the headpipe bolts and all is good! Not saying they couldn't be leaking but the bolts are tight!
What about EITMS? And how does that play with with the Power Commander? Since the PC adds a percentage of fuel, will it cause fuel to be added while EITMS has been activated?
I know this is turned on and with it being so damn hot here in Dallas, the rear cylinder has been shut down a few times at red lights
Received 70,429 Likes
It hasn't been dyno tuned. Before I do that, I would just pop for AutoTune to go along with the PCV. The only reason I haven't done that already is that I would have to replace the headpipe as the O2 sensors for AutoTune are different sizes than the ones on my bike (and they need to be closer to the head too, I believe).
