Harley quit
Start with the basics:
- Is there gas in the tank?
- Are the battery cables tight?
- Are all the plugs pushed in all the way?
- Do a fuel pressure test.
- Do a compression test.
- Check for spark. (You need to keep the spark plugs in and use a spare plug to check due to sensors cutting the spark if there is not enough cranking pressure).
Bigfatty
08-05-2021 10:39 PM
motochick55
33
08-10-2019 03:54 PM
sharkbait1
12-27-2017 12:13 PM
