14 48 started idled then died. Wtf
Hey guys. Started I'm bike this morning last time I run it was last week. It started up fine. I let it idle for 5 minutes my girlfriend sat on the back and it shut off. Hasn't started since. The check engine and red lights on. All head and tail and blinkers work fine. Sometimes it will try to turn over other times absolutely nothing when I hit the start button. Any thoughts? Thanks
When the check engine light comes on it means the bike threw a code, so check for them.
See if your battery and ground cables are clean and snug. If they are good, then charge up the battery and see if that helps. And if that still doesn't work, take out the battery and get it load tested. My guess is your battery is shot.
Really? Right next to the starter button.
Having a Fuelpak doesn't mean you can read the codes:
https://www.hdforums.com/forum/ignit...tic-codes.html
Check your Fuelpak connections, too.
