2007 Ultra turns over won't start
tach movement means crank sensor is working
pump on at key on means electrically pump functions
need to verify pump back on when cranking
should do fuel pressure test
If it fires you have spark. If not need to test spark properly
You state all fuses are good and pump cycles so thats a plus
hdchaplain (10-15-2016)
It is doubtful you have a clogged filter at that mileage but possible.
This also assumes the gas in your tank is good but uou said the plugs were dry after cranking
randyw
08-29-2020 12:06 PM
