Mod to 2016 air cleaner
msocko3 (10-09-2016)
HD-1614 is the KN PN for a filter for the touring.
Zippers manufactures a Stage 1 filter that comes with a cleanable unit and utilizes the stock cover. This is the same one other dot com store relabeled as their own.
Like is mentioned. The stock AC is a good unit and isn't a choke factor for up to a mild stage 2. How the stock one is designed. It helps with not pulling hot air off the engine. The aftermarket ones slot the backing plate that does allow hot air to be pulled off the engine. Something to keep in mind.
If your bike is stock, leave the a/c stock. Otherwise a hi flo a/c may be worth considering. Depends on what you have and want.
One sheet is a cammed pre-rushmore 103" comparing a KN filter and Crusher Street Sleeper III a/c. Same day, same bike... The tuner also removed the filter, running open air, and the sheet was exactly the same as with Crusher filter installed.
The FM chart compares stock rushmore filter to their hi flo a/c.
+1. I ran the Screamin Eagle AC for a while and there is no difference that I can see. I did tune it with each different filter on too. The only difference with the SE AC is that the intake is way louder when you get on it. That's why I changed it back...plus it's easier and cleaner to run an external breather on the stock set up.
FFChuck
Exhaust System Topics
16
10-25-2018 10:21 AM
martin10
Milwaukee Eight (M8)
17
12-28-2016 11:32 AM
