14 Wide Glide extended crank floods engine
Have a factory stock 2014 Wide Glide (19 miles on it, out of factory warranty) that has extended cranking and soaks the plugs when trying to start. When it starts running, it usually stalls but runs a little better when warmed up.
It has no codes, battery load tests ok, the grounds all seem ok...the tank, fenders and battery cover were removed for paint. I am thinking that something must have been disconnected/pinched when this was done but I have not found anything yet.
Has anyone seen anything like this on the newer bikes? Seems like the can bus limits what you can do with troubleshooting.
whitecoyote
08-28-2011 02:33 PM
