Dtc po131 po151
Do the codes come up together? Reason I ask is a friends 2006 Street glide was setting the same codes. Had him replace the system relay and it fixed the problem.
Took the old relay cover off and you could see pitting and darkening on the relay contacts.
It's unusual for both O2 sensors to trip the codes together. The system relay is the common thread to both of them.
System relay
