I miss my old carb'd bikes! Help Please!
My original thread: https://www.hdforums.com/forum/engin...-and-dies.html
Long story short, I have a 2001 Softail Deuce Fuel Injected bike. The PO has a RevTech DFO that is installed after the ECU.
This thing will not idle at a steady RPM for **** and coughs through breather like it's got emphysema.
Until my tuner arrives, I bought a 4 pin to OBDII adapter and downloaded HarleyDroid to read the error codes.
Here is what I am getting:
P0505: Loss of Idle Speed Control
P0122: TP Sensor Open/Low
P0261: Front Injector Open/Low
P0263: Rear Injector Open/Low
A couple of things.
I have replaced the TP Sensor, but I ran the bike with the TP Sensor unplugged and I suspect that is when that code was thrown.
I cleaned the original Idle Air COntrol valve by removing it and cleaning it with Carb cleaner. I have been told I should have used MAF Sensor cleaner. This is still the original part.
Injectors. I can only imagine that the DFO is screwing this up. Either that or the injectors have taken a righteous dump or are leaking (I would assume I would smell gas)
Anyways, would it be safe to assume I may also have the dreaded pin hole leak that would throw the injector codes? I am hoping the answer is yes because I have ordered all the parts to replace those pieces.
Thanks for your help and have a Merry Christmas!
A couple of things.
A couple of things.
A couple of things.
ironrhino (12-16-2016)
You should also check for a broken wire to one of the fuel injectors. Overly tight tie wraps have been known to cause the leads to break and cause problems. Check by wiggling the wires while running or with a DVM as they can break inside the insulation and be difficult to find.
Quick update and if anyone wants to correct me, please do.
If you Google pin hole leak for Harley or search on YoutTube you will be met with a lot of helpful videos showing how to fix it. It doesn't necessarily show what it looks like. I am pretty certain I have non-consistent fuel pressure because of this, therefore causing the bike to idle erratically and overcompensate by trying to dump more gas causing it to run rich and not stay running.
Tonight I took the tank off to remove the DFO and check the injector wires. Got that done and put a quick disconnect on the crossover fuel line.
Put the tank back on and put about 20 oz. of gas in just to get it running. I decided to look into the filler hole and guess what, pump ran and sprayed gas all over the inside of the tank.
Here is the quick video of it happening:
So with that being said, I think I found the culprit and should have gone with that from day 1. Now I wait for the parts to come in.
FattyMcJ (12-21-2016)
