Tuner
Like other have said either the tts master tune or the power vision. I have both and prefer the power vision because of its easier to use, especially if your not sure what your doing and you don't need a pc to use. After using the tts master tune for a while and figure out how it works it's it's not bad but you do need a pc to use. Both work very good.
Just make sure you buy the right one the first time.
You might not think you won't ever do more then the stage one stuff,but you will.
