Starter relay clicking, but starter not engaging
Old 02-19-2017, 09:31 AM
Jimsjax's Avatar
Jimsjax
Jimsjax is offline
1st Gear
Default Starter relay clicking, but starter not engaging
2003 Ultra Classic. When I hit the ignition the relay is clicking, but the starter is not engaging. I have a manual push button on the starter. When I use that, the starter does not want to disengage when I release it.
Old 02-19-2017, 09:39 AM
Big Dave's Avatar
Big Dave
Big Dave is offline
Received 1,011 Likes on 558 Posts
Sounds very much like a low or bad battery - Charge the battery fully and try again
Dave
Old 02-19-2017, 09:44 AM
Jimsjax's Avatar
Jimsjax
Jimsjax is offline
1st Gear
Battery is fully charged.
Old 02-19-2017, 10:18 AM
Big Dave's Avatar
Big Dave
Big Dave is offline
Check all your ground wires battery connections etc
Was it working before ? I mean has it been sitting a while and this is a new problem
Just checking are you using a meter to check battery voltage
Dave
Old 02-19-2017, 10:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Do the simple stuff first, make sure the battery is fully charged and then have it load tested.
Clean all electrical connections, the small ones on the relay and solenoid, and the battery cable connections.
Old 02-19-2017, 11:11 AM
Jimsjax's Avatar
Jimsjax
Jimsjax is offline
1st Gear
I was having intermittent problems with it. Then it would not engage at all. Replaced starter and bench tested relay. All connections are brand new. Battery is almost new. Used voltage meter to ensure battery is charged.
Old 02-19-2017, 11:35 AM
Big Dave's Avatar
Big Dave
Big Dave is offline
A fully charged battery will show approx 13.5 volts on a meter - if you have three hands you can try this - with the meter on the battery reading full voltage try the start button how low does the voltage go ?
A load test is really required just to take the battery out of the equation
Dave
Old 02-19-2017, 12:42 PM
Jimsjax's Avatar
Jimsjax
Jimsjax is offline
1st Gear
12.7 at rest. Dropped to 10.9 pushing the ignition switch.
Old 02-19-2017, 01:05 PM
Big Dave's Avatar
Big Dave
Big Dave is offline
I would get the battery load tested , its a free service at most auto part store
Dave
Old 02-20-2017, 09:14 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,252 Likes on 3,626 Posts
If you are getting 10.9 at the starter and it ain't spinning, the starter is kaapoot..
Quick Reply: Starter relay clicking, but starter not engaging
