My iron883 suddenly died
Old 03-25-2017, 10:49 AM
iron883dreamer's Avatar
iron883dreamer
iron883dreamer is offline
5th Gear
Default My iron883 suddenly died
So.. a lot of thing happened.. theft on our work shop got stollen all tools but bikes.. so I'm very thankful. Anywau, so I was starting my bike since I haven't used for few weeks and all the light works but when I push start button bike doesn't even click.. just none. i checked battery it is full. Almost 13.5v.. what else should I check? Any tips?
I don't think thief touch my bike..
Old 03-25-2017, 12:09 PM
nevil's Avatar
nevil
nevil is offline
First check your battery and ground cables, should be clean and tight. Then get your battery load tested because a sitting voltage reading won't tell you if you have enough cranking power.
Look at all your fuses and relay connections.
Make sure your kill switch is in the right position.
Bluesrider
06-07-2023 09:38 AM
Peranadar
12-22-2017 09:21 AM
mlrailguy
08-16-2015 06:49 PM
Jody858
09-08-2014 04:52 PM
mike06train
07-06-2011 10:36 PM
Quick Reply: My iron883 suddenly died
