Blown Ignition Fuses
My 2007 Streetbobblew threeignition fuses in 200 miles. This all happened after a front turn signal relocation. I tripple checked my work for shorts, nicks, or pinched wires. Took it to my dealer. It blew some fuses for the tech at first, thenhe started checking wires and now it won't do it anymore.The problem is thathe said he couldn't find anything to fix. He test rode about thirty miles and it's ok but I did the same thing and when I thought everything was cool, it left me sit. They're waiting for a call back from the factory tech and I have no bike. The bike would start but when I would try to pull out it would blow the fuse again. They tested all the wires and everything came up fine. would a bad TSM module blow ignition fuses? Also, what does the system relay control? I don't want to be a damn guinea pig to see if it's fixed and be stuck out in the middle of nowhere. The last time was on Sunday evening and I had the ol' lady pull me with the truck. That was not fun.
mtl4490
08-13-2008 08:39 AM
shoptroll
07-08-2007 07:18 AM
