Can't find B+ connector on an '08 EGC
Old 11-12-2007, 11:40 PM
thatguy's Avatar
thatguy
thatguy is offline
Default Can't find B+ connector on an '08 EGC
Installing heated grips on my '08 FLHTC - doing fine until I get to the part where it says Locate the B+ connector on the main electrical harness under the seat (a red wire with an unused gray connector). Have searched all over, have pulled both side panels off - this connector is nowhere to be found. Does it exist on the '08 models? Thanks in advance for anyone that can help.[/align]
Old 11-13-2007, 10:23 AM
BlkSilverado's Avatar
BlkSilverado
BlkSilverado is offline
Default RE: Can't find B+ connector on an '08 EGC
Did you try lookingunder the triangular shaped plastic cover under the seat, by the gas tank? may be hiding in there...
Good Luck..
Old 11-14-2007, 12:35 AM
thatguy's Avatar
thatguy
thatguy is offline
rocknrod nailed it.... it was in front of the battery, but tucked down low under a few wiring harnesses... couldn't see it from the top, he found his by viewing it from the right side - but the ABS on my bike blocked my view on that side. Grips work great If I had to do a 2ndbike I could do it in half the time.
Toe Knee
01-19-2012 03:27 PM
streetglidedean
08-03-2011 05:47 PM
09redhotsmokeyultra
12-19-2009 10:49 AM
MZBuckeye
10-14-2008 06:52 PM
masterblaster
01-12-2008 01:18 PM
Quick Reply: Can't find B+ connector on an '08 EGC
