Fuel Injector Cleaning
RE: Fuel Injector Cleaning
Really though.....if you ride on a continue basis and never let your gas go stale, then you probably don't need any fuel injector cleaner.
Todays gasoline is pretty much clean and has additives built in to keeping your system clean. If you were to encounter problems such as rough running, poor fuel economy...etc. Then I would consider trying some fuel injector cleaner. If your bike is running good now.....I would just continue on riding.
joellynn3...I also have an '04 RKC. I ran a bottle of Techcrolene (sp?) through the motor. I added about a 1/4 of a bottle everytime I filled the gas tank. Truthfully, I didn't notice any difference, so I guess everything was ok to begin with. Regardless, it made me feel better to have done it.
I use Lucas gas treatment in my motorcycle for the injectors, fuels are produced basicly the same. The difference comes in when they are put into a vendor's tank in the ground, this is where contaminaton comes into play.Any time you move fuel from one container to another you take the risk of contaminaton. Just because you have a clean container dosen't mean the other guy does.The injector cleaner can help with the contaminents. It is always a good idea to do the most for your machine, in whatever way you can.
I repair gas station equipment for a living!!!Shells addtive when it first came out played hell on the meter seal and valve inside the gas dispencer Gilbarco and Waynes.they have a additve for cleaning as do Chevron.the mfgs changed ther seal material mainly for shell due to the problem with there additive.Chevron never had this problem that i know of. That said ALL GASOLINE are EQUAL up to the point when they add there additive MONEY-MAKER.If you check tank farms where they get gas youll see different brand(s) of trucks they just add there additive and now you have Shell,Chevron ,Citgo,Beacon,GAS n GO,ETC.as long as you dont let set to long (Newer gas formulas doent get-"gummy" as fast) and if your ride it kept in tune putting a Extra additive is YOUR CHOICE.Does anyone remember checking the plugs for lead deposits,oil fowling,etc.Next time you spill or top off you car remember back when the gas use to SMELL and turned your hands white and it took a time to evaporate.The dispencing devices of now adays dont clog up or need cleaning no matter with or without additives.Think about that.
Q103 (04-13-2020)
