andrews coil
Old 10-21-2007, 06:38 PM
georgedexter's Avatar
georgedexter
georgedexter is offline
Stage I
Default andrews coil
I AM WIRING UP A 1953 FLH. I AM USING A NEW (GREEN) ANDREWS COIL BUT I AM NOT SURE WHICH END IS POSITIVE. THE COIL WILL ONLY MOUNT ONE WAY. THE COIL IS STAMPED "ANDREWS". IS THE 'A' END (top )POSITIVE OR THE 'S'END(bottom) POSITIVE? I HAVE A MALLORY IGNITION WITH THE STANDARD THREE WIRES,RED, GREEN AND BROWN. CURRENTLY I AM RUNNING GREEN TO THE BOTTOM OF THE COIL,RED TO THE TOP,ALONG WITH WIRE FROM IGN.SWITCH. DOES THIS SOUND CORRECT? THIS SOUNDS LIKE A DUMB QUESTION BUT HELP... I AM WIRING FROM SCRATCH WITH NO DIAGRAM. THANKS
theterribleone_vdc
Shovelhead
02-26-2017 02:40 PM
lagunatic
Shovelhead
01-17-2013 05:36 PM
tymatt67
09-23-2012 08:54 AM
charleysharley
Ironhead
29
10-24-2011 03:47 PM
shovelthecoochie
Shovelhead
01-27-2007 05:46 PM
Quick Reply: andrews coil
