EFI TO CARB
EFI TO CARB
I HAVE A 97'ELECTRA GLIDE CLASSIC I AM INSTALLING A S&S 96"MOTOR IN IT.I WANT TO GET RID OF THAT GARBAGE INJECTION AND MAKE IT CARB.IS THERE ANY COMPLETE KITS OR WAYS TO DO THIS WITHOUT RE WIRING THE BIKE AND BY PASSING ALL THE EFI B.S. BUT STILL ALLOWING ALL MY GAUGES ETC. TO OPPERATE?
RE: EFI TO CARB
Mike I disconnected the entire ecm, renoved the efi harness, unplugged all the sensors. I replaced the efi harness with a carb harness, it plugged right in. I put a carb manifold on bike, connected the carb. I put a carb ignition/coil on. I disconnected the efi fuel hoses in the tank, left the pump inside. Bike ran great.
RE: EFI TO CARB
Here are the parts for a '01 conversion. They should be same or similiar.
[b]Engine mount (with slot for choke) ……. 16315-99 $5.51
Choke cable ……. 29229-88B $8.80
Choke elbow ……. 27580-88 $2.18
Choke boot ……. 27582-88 $1.78
Intake manifold ……. 27613-99 $22.43
Manifold seals ……. 26995-86B $1.51 X 2
Seal ring (carb/manifold)…… 27002-89 $4.91
Ignition Harness ……. 32435-00 $104.43
Manifold sensor (MAP) ……. 32316-99 $26.95
Manifold sensor seal ……. 11291 $0.99
Retaining clip ……. 38723-99 $0.13
Retaining clip screw ……. 68042-99&nb
