Average lifespan of a starter?
RE: Average lifespan of a starter?
ORIGINAL: xxxflhrci
Did the starter go bad or were your solenoid contacts just worn out?
If the starter was spinning, which is what gives off that sound, you do not need to replace the whole starter. You only need to replace the starter drive clutch.
http://cgi.ebay.com/ebaymotors/ws/eB...m=370022435006
I've never had a starter go out, except a starter clutch on a '95 Dyna, but that was a common problem with that year model and some '96's. My last bike ('96 RK) now has 114k on it with the original starter, and no problems with the starter clutch either.
ORIGINAL: iclick
Hope they didn't rip you off for a new starter.
When I put the bike in the shop, I asked them if it could be something other than the whole starter and they said they would do a diagnostic on it to see. They called me latter that day and saidthe starter would need to be replaced.
Ask them if you can have the old starter back. You're entitled to it. See what they say. Sure sounds like it was just the solenoid. Might even tell them you're going to test it or have someone check it out. If nothing else, they may adjust the price down. Good luck.
