3 codes on 07 sg
Old 05-15-2008, 09:36 PM
jeff986301's Avatar
jeff986301
jeff986301 is offline
Default 3 codes on 07 sg
just did stage one with a fatcat pwr111 and a big sucker, bike runs great, the first code is po152, a rear o2 sensor high (rich), by the way i did remove o2's as instructed, by pwr111, the second code is a p1352, a front ignition coil high/shorted EFI, the 3rd is a p1357, a intermittent secondary front EFI, did i mention the bike runs great, thanx all for the input
Old 05-15-2008, 10:25 PM
White Knight 04's Avatar
White Knight 04
White Knight 04 is offline
Default RE: 3 codes on 07 sg
There is a way to clear all the codes do that and see if the codes are current or came about after you did the Power C111... Clear them and if they come back you have problems but if they don't show up again your ok....I have a suspicion that they will be gone....
ScottA320
04-05-2018 08:14 AM
Casting Crowns
02-27-2013 08:36 PM
oct1949
10-08-2010 03:25 PM
jeff986301
05-15-2008 10:27 PM
jeff986301
05-15-2008 09:25 PM
Quick Reply: 3 codes on 07 sg
