Help 06 Night Train only one cylinder firing
My friend's 06 Night Train all the sudden started only firing on \\;one cylinder and the check engine light came on last week, this happened after ridding about a hundred miles and then it started running OK for a while then it did it again a couple of more times during the last 50 miles. \\; \\;
Since we had just gotten gas, we drained the gas and changed the plugs and checked everything over. \\; All seemed OK and today it did it again. \\;We checked the codes and had the 3 codes below in order.
P00265 - Battery voltage low
P1355 - Rear ignition coil high/shorted
P1352 - Front ignition coil high/shorted
We checked all the connections, plug wires \\;and looked at the coil and saw nothing. \\;The battery light did come on one time for a couple of seconds, but the bike starts fine and lights are bright even if it is not running. \\; We then cleared the codes and took it on a test ride again tonight. \\;Again 3 times in \\;a 20 mile ride it did it again. \\;The check engine light came on and it started running on one cylinder. \\;Seemed to happen just after harder acccelleration and only lasts a few seconds. \\;The light goes off and it runs OK again.
Anyone have any idea on what this could be?. \\;\\\\\\; His warranty just ran out about a month ago.
piniongear
18
08-26-2014 02:56 PM
