2001 Deuce Starting Problem
Picked up clean 2001 Deuce about a month ago. \\; Had what \\;appears to be 1100 original miles.
Starter button has begun to work intermittantly. \\; Doesn't appear to be a weak battery (less than a year old according to battery). \\; Always \\;turns and fires strong when it does decide to respond to button being pressed. \\; Seems to be worse when bike and outside temperatures are hot (S. Florida climate)or when it's sat for a few days. \\; Sometimes I'll have to hold my thumb down on the switch for 5-10 seconds before any response. \\; Sometimes it helps if I apply firm pressure to the center of the switch and then "roll" my thumb down while pressing switch. \\; Sometimes it doesn't work at all. \\; If I leave it and come back in an hour or two it might be fine and fire right up. \\;
Is it possible it's just a bad switch needing replacement or possibly a relay, etc...?
Ordered a HD shop manual from dealer-hasn't come in yet.
Any input would be appreciated.
Thanks.
Thanks.
RE: 2001 Deuce Starting Problem
Thanks for the fast reply Doc.
Is the relay (Starter relay?) one of the items situated just behind the battery near the fuse center?
If it is...looks like an inexpensive snap-in item. \\; If not...can you give me an idea where to look.
Also, is switch a snap-in component (once I have the control housing cover removed?) as well?
Thanks
Thanks
The starter relay is where you said it is and it is a snap to replace, however the starter and run switch (combo) is a screw in and snip wires, re soldier, tuck away neatly, pinch a wire a couple of times as you assemble...(no don't do that )..lol. \\; The switches are a pain in the butt to change.
 \\; \\; \\; When it rains it pours \\; \\; Im hearing a lot of this problem lately. I still have it also and its not the relay. I have a hard time beliving the switch is heat sensitive but maybe because it works if I let it sit awhile Rather than finger the button I carry a jumprr wire and go from the solenoid to the plus cable and away I go . Maybe I should go back to riding my KICKSTART
 \\; This is from Sport King
I would carry a multi meter to analyze what would happen when it didn't start. I would pull the connector from the solenoid then check for voltage when the button was pressed . That confirmed to me the button was working .I  \\;believe I would get say 10.8 - 11 Volts now that's with ignition on and headlights on. \\; Also I am able to hear the contacts slam in the solenoid when this problem happens . I \\;have checked them for alignment or pitting . \\; This normally would make me thing the problem is either a bad hold in winding in the solenoid or a dead spot in the armature . \\; But when I place a jumper from the battery cable attached to the starter to the solenoid it starts . \\; Doc \\; can you cast some opinion on this ? Eventually I will change the switch pair but as you said its a big PITA especially when its wired internally through the handlebars
