"Master Reset"
"Master Reset"
If I do the master reset procedure, does it put the ECM back to factory stock (assuming a stock engine - no SERT)? That is, I understand the ECM "learns" as you ride. I put XiEDs on there and my mileage dropped by 25%, so I want to return the bike to stock. I've removed the XiEDs.
To do the master reset, do I have to be in the diagnostic mode or just do the key on/off/on/off/on and then left turn signal?
Oh, and will it do anything to the security module or will it still work normally?
Thanks!
Thanks!
Jpatrosso
24
02-02-2019 01:03 PM
