o8 electra glide classic speedo installation
Get a manual and follow the instructions......
Or you can remove the outer fairing, remove the 2 screws holding the bracket to the back of the speedo, remove the odo reset button cover, GENTLY unplug the socket from the back of the speedo.... Reverse operation with new speedo...
Just incase that the bike doesn't start, then you will need to do a password learn procedure....
