Question about Harley-Davidson SEŽ Pro Super Tuner Cable Kit 32184-08
Old 09-13-2008, 03:35 AM
mrbadlands's Avatar
mrbadlands
mrbadlands is offline
Default Question about Harley-Davidson SEŽ Pro Super Tuner Cable Kit 32184-08
Greetings,
A friend has purchased me a SERT Pro but failed to realize they needed to order the cable kit. From all I can see from pictures, it looks like a garden variety USB to mini usb cable. Is this so?
Thanks in advance
mrbadlands
Old 09-13-2008, 07:50 AM
HRLYSG's Avatar
HRLYSG
HRLYSG is offline
The USB cable is a generic cable. I use a 10' cable I had laying around. The other cable is the what you really need unless you make one up.
Old 09-13-2008, 11:45 AM
mrbadlands's Avatar
mrbadlands
Oh I see now. I wasn't aware it was 2 seperate cables. Every picture I found showed the generic USB cable. At that rate I better get on the ball and order that cable kit so it will be here when the SERT arrives.
Thanks!
Royce
Old 09-13-2008, 02:21 PM
oldfartjc's Avatar
oldfartjc
oldfartjc is offline
Thanks!
Royce
I can't believe that the MOCO quit sending cables with the older SERT and now even with the newer SERT. What a bunch of cheap asses not to give $3.00 worth of cables at the most with something you spend over $500.00 for.
Old 09-13-2008, 08:33 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,415 Likes on 1,566 Posts
We were on the fence when HD decided to remove the cables from our kits (SERT) but the dealers didn't want them as they had hundreds already. HD removed them and added a second part number for them which was fine. Only problem is they didn't drop the price! In our new kit we followed with no cables but we reduce the cost of the kit. That way if the dealers do not want them the cost is less but if you need them they are there to be purchased
Old 10-14-2009, 04:16 PM
toddki's Avatar
toddki
toddki is offline
4th Gear
Default computer requirements
I got the new super tuner about 9 months ago it works great. I think its a little buggy but i was used to the sert. I'm thinking about getting a palm computer or a micro laptop to have in the bag for tunning but I can't seem to find what requirments are needed for the computer ie. memory does anyone know?
Toddki
2007 Roadglide
117 cu.in motor
264 SE cams
Rhinehardt 2-1 pipes
50mm throttle body
Hot shot ported heads
Modified big sucker air cleaner
xkvator
11-13-2010 05:10 PM
Bobbed Out
01-29-2010 05:58 AM
RustyCor
09-30-2008 06:00 PM
asuperheat
12-06-2007 11:24 PM
woosh
03-14-2007 12:18 AM
Quick Reply: Question about Harley-Davidson SEŽ Pro Super Tuner Cable Kit 32184-08
