HD High Performance Ignition Modules
03-28-2005, 12:49 AM
Does anyone have experience with HD high performance ignition modules for the EVO big twins? How about the following:
Curve….Part Number….Type
E….….….32419-91A…...Police
F…….…..32595-96…..…SE Late Style Plug
F….….….32596-96…..…SE
P….….….32630-96…..…SE
03-28-2005, 03:00 AM
RE: HD High Performance Ignition Modules
From what I understand, the HD modules are "so - so"...essentially not much more than an increase in the rev limiter.
For the money, a Crane Hi-4 single fire is a boost and well worth the few added bucks...allows independent timing of the rear cylinder.
I run an Hi-4 on my FXSTC and noticed a huge improvement over the SE plug in module.
03-28-2005, 03:24 AM
I think you'll find the spark output the same- just different settings for the different application cams.
BRUCE
03-28-2005, 11:07 AM
I have briefly looked at some of the Crane ignition systems. Which one does your bike have? 8-2100 Single fire or
HI-4E Ignition
HI-4 PowerLink Ignition
HI-4 Single Fire Ignition
Other….
Did you also go with one of the Crane coils?
Thanks!!
03-28-2005, 11:24 AM
Hi-4 single fire, and yeah...ya have to go to a performance coil...not necessarily Crane...Spike makes one that fits under the stock cover...40K volt, I believe (I used a Crane)
John1957
Shovelhead
07-22-2012 03:08 PM
SAS
09-30-2008 09:01 PM
badinfluence63
08-08-2008 10:07 AM
deadskull
09-14-2006 04:44 AM
HaggisMan14
06-15-2006 05:51 PM
3241991a,
3259696,
eagle,
foruns,
harley,
harleydavidson,
ignition,
module,
modules,
part,
parts,
performance,
screamin,
screaming,
stock
