TTS Mastertune Information
#3352
Yeah, Jamie at Fuel Moto, who I bought the cam from, told me not to wste my money on head work until I go to a 107.
The head tech at a local dealer, who I was told works with and trains race teams, told me a 107 wasn't a good idea because of heat and that thinning out the block that much leaves it as a potential catastrophe. I haven't looked at the block specs to see if what he said has any merit at all, and I'm not going to 107 until the winter.
#3353
I used to do business with a dealer who had techs that kept telling me I shouldn't believe what I read on the Internet. The longer I hung around the more I noticed they were nothing more than parts changers.
#3354
#3355
Don't max out your Throttle Blade Control unless you want to wear out your TCA. Leave it to Original.
If that doesn't help then flash a canned calibration in to see if it is the calibration. If it isn't, good luck. Rumor has it that the throttle body TCA's are going bad and Harley has a new design being released in a few weeks... this is only a rumor.
Open your air cleaner... blip the throttle and see if your butterfly opens up, shutters back down then opens up in a split second. That's your bog. How to fix it is anyone's guess.
#3356
#3357
Since I changed my cams I need to go out and collect data. I loaded Vista SP2 on my Macbook Pro and installed and updated the software with all the latest updates. Obviously I set my laptop to never go to sleep or turn off the hard drive, but I have a question- do you guys lock your computer when riding for data so no keys get pressed? logically the laptop is continues running applications when you lock the computer ( like when you walk away from it and don't want anybody looking at your stuff), but every program has it's quirks and I don't want to waste any runs for data.
So, yes to "lock computer" when taking your laptop for a ride?
#3360
I replaced cams at about 5200miles and had to replace one of the stock lifters because it wasn't pumping up and holding pressure. After looking at your picture I went to the garage and snapped these ones of the lifter I replaced. Similar pattern. I've got 16,000 miles on it now and 4 Gaterman 1023 lifters sitting in my toolbox. Guess I should think about putting them in soon.
