TTS Mastertune Information
  #4341
Old 10-18-2013, 06:16 PM
NavyPride's Avatar
NavyPride
NavyPride is offline
6th Gear
Originally Posted by UltraNutZ
I had the D&D 2:1 setup, the fullsac 2:1:2 and rinehart 4" setup, and now the fullsac 2:1:2 and thunderheader setup.
The D&D IS WITHOUT A DOUBT a performance setup and the best performing setup I've ever had on a bike. I noticed a huge difference after removing it but I did remove it for other reasons, too loud for me.
Also if you're worried about having that "bagger" look with your exhaust, then get the ghost pipe.
I definitely do not want to get loud with the exhaust, so I was looking at the quiet baffle. Do you have any knowledge of how loud that baffle might be? I would like a better HD sound than the stock pipe but I can't get too loud w/o upsetting the wife. I am interested in something with a deep throaty sound on accell and decel but gets quieter while cruising.
If I need to take these questions to another forum just let me know? I don't want to clutter the TTS forum with unrelated questions if it is a problem?
  #4342
Old 10-18-2013, 09:18 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
As promised.. Here are some hints to get you started.
It will take you from purchase to VTune in the proper order as needed.
  #4343
Old 10-19-2013, 03:23 AM
Sparra's Avatar
Sparra
Sparra is offline
Where do I find the FR program...I just updated everything and I can't see it or I am doing something wrong...
Ok I just ran the update again and it say's that the flight recorder is not installed...Where do I get it???
Update...Just worked it out...
Cheers...Sparra
  #4344
Old 10-19-2013, 08:36 AM
MattyAmber's Avatar
MattyAmber
MattyAmber is offline
good write-up Wiz, now if I only had the blue instead of a undated SERT!!
  #4345
Old 10-19-2013, 10:46 AM
BearShit's Avatar
BearShit
BearShit is offline
WELL..first run no Data, shame had nice hills to..reload FR 2 hr head home,download 4 files recorded..very small files 4000, 8000 hits not much histogram wise ?? Would there be a difference if i accidentally loaded full map rather then map adjusted for Vtune ??? gonna try sneek an hour in before the rain hits here ..and read help files quick although it does seem fool proof..
  #4346
Old 10-19-2013, 12:59 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Those are extremely small files. 30,000 + is more like it.
I would definitely recheck to see if you have a VTune file in your bike. There will be no data in open loop.
  #4347
Old 10-19-2013, 06:46 PM
BearShit's Avatar
BearShit
BearShit is offline
K thanx Wiz, rain beat me to the punch, tomorrow no rain 10celcius but dont matter...wish there was a way to pull the tune out n double check..but i just reloaded file to make sure.. bunch a u guys been help all summer..no one up here touches TTS other then me .!! just as well OCD kicks in haha
  #4348
Old 10-20-2013, 08:18 AM
grasmo's Avatar
grasmo
grasmo is offline
I think I am in the right section....TTS is the same as SERT or close to it???
My 110 with 585's has a rear cylinder issue sounds like maybe the timing is moving around at idle......inconsistent idle problem....Can you point me in the right direction..I will gladly pay a tuner to make the necessary adjustments.
  #4349
Old 10-20-2013, 08:38 AM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
For $100 bucks you can upgrade to a TTS Black Dongle then go see Doc in Minneola.
http://www.docsperformancetuning.com/
  #4350
Old 10-20-2013, 09:29 AM
mr_gdr's Avatar
mr_gdr
mr_gdr is offline
I want to under stand this before I start,
when do I hook up the lap top to the Communications interface to the bike?
I can guess,,, but I don't want to mess any think up.
this is what you said to do.
(Can?) Cam selector:
Start up the bike and warm it up until is at warm idle.
Turn the bike off.
Open DataMaster.
Select File> Data Recording (proper ECM such as J1850)> Cam Tune Data
Save the data file in your desktop folder.
Start the bike and let it come to warm idle again.
Start the data recording.
Time the data recording to 3 minutes.
Turn off the data recording first.
Turn off the bike.
Open the data file in your desktop folder.
Select View> Camshaft Analyzer> Opening
Read the manual how to analyze the graph.
Open your VTune-001 in MasterTune
Open Table Selection> ECM Tuning Constants.
Reset your IVO (Intake Valve Opening) Cam data in the Cam Selector. Leave the IVC
alone for now.
Save the VTune file as VTune-001
Flash the new VTune-001 file as above in Flash the Bike.
Start the bike to see how it idles.
If it is a rough idle go back to your Cam Selector and chose the IVO setting one number lower.
Save the file as VTune-001 and flash the bike.
See how this calibration idles and chose which IVO idles the best. Change the IVO to the first number if the bike idles badly and reflash.
Quick Reply: TTS Mastertune Information
